TwinTurbo.NET: Nissan 300ZX forum - Usually a Check Engine light
Subject Usually a Check Engine light
Posted by Noncon on May 07, 2008 at 7:03 PM
  This message has been viewed 153 times.
In Reply To Symptoms of an inoperative ECU chip??? posted by nismo_boost31 on May 06, 2008 at 10:06 PM
Message Are you using one of the diagnostic software i.e Conzult? If so what is the A/F Alpha when running lean? If it is high (above 105) it means the ECU sees the lean condition and is trying to adjust for it, so ECU is doing what it is suppose to.
Have you checked the O2 sensors?
KJ
